Online Now [500]:
Visitors: 499
Today: 150128
Total: 155241986
Forums › The Car › 206 Problems › Gti 180 rear lateral arm
Dan-
PostPosted: Sun Feb 20, 2011 3:52 pm Up
Hi there, I own a 180 and recently had an annoying knocking coming from the drivers side rear, so jacked the car up today and pulled around and the only thing I could see to be the cause was the ARB? The 2 bars that connect to the Axle and the hub. I removed both of them lowered the car and took it for a test drive, all seems to be okay the knocking has gone, is there any drawback to removing them? And will I be able to buy new bushes or will 2 new bars be the easiest way.
Thanks dan
PostPosted: Sun Feb 20, 2011 3:56 pm Up
they are not anti-roll bar, they are the lateral arm/bar
PostPosted: Sun Feb 20, 2011 4:18 pm Up
is your car lowered?? probably the exhuast hitting the n/s bar over heavy bumps mine did this occasionally on the bumpy roads near me cable tied a bit of rubber to the arm and its fine now Very Happy
Dan-
PostPosted: Sun Feb 20, 2011 4:32 pm Up
The front is lowered 30mm but the back is still standard,
Lee.
PostPosted: Sun Feb 20, 2011 4:50 pm Up
I had a knocking on my old 180, would have Put every penny I had on it being the back, had every bush on the back changed etc, went for MOT, had a £12 front droplink changed and hey presto knocking was gone! I genuinely believed it was coming from the back! Just a thought......
Dan-
PostPosted: Mon Feb 21, 2011 2:48 am Up
Cheers I'll check the droplinks to see if there's any play in them, I might just put new 1s on to rule out any front knocks
Lee.
PostPosted: Mon Feb 21, 2011 3:46 am Up
It's worth it mate, I spent a couple hundred on the back, £12 on the front fixed it lol
