Latest: eltel666
Overall: 17146
Online Now [70]:
Visitors: 69
Today: 19691
Total: 116242379
Forums › The Car › 206 Problems › Drop link siezed
Drop link siezed
Dan-
PostPosted: Sun Mar 27, 2011 8:00 am Up
Hi there I'm trying to change my drop links, I've managed to remove the bottom nut but the top 1 won't budge and now has rounded off, how do I go about getting it off now Sad
Cheers Dan
SDK206
PostPosted: Sun Mar 27, 2011 8:05 am Up
as in the nut won't turn at all??
If in doubt, drop a cog and put your foot down Smile
Dan-
PostPosted: Sun Mar 27, 2011 8:09 am Up
Yeah the nut turns but spins with the torx bit also but now the torx bit has rounded so i can't get anything to lock the bolt while the nut spins off
SDK206
PostPosted: Sun Mar 27, 2011 8:10 am Up
If it won't turn at all couple of options 1) coat it in releasing fluid ie wd40 a leave overnight 2) use an impact wrench, if you can get the use of one 3) use a big breaker bar to crack it off or worst case oxyactelyne gas axe!!
SDK206
PostPosted: Sun Mar 27, 2011 8:13 am Up
if the whole lot is turning in ball joint socket, turn on opposite lock and get a good pair of mole grips lock them on tight then turn back the other way and try again!!
an impact wrench is best as it shakes the crap off the threads when you start buzzing it off Smile
robdob
PostPosted: Sun Mar 27, 2011 8:24 am Up
Oxy acetylene seems a lil ott tbh.. Your more likely to melt it for good and fuse the metals together and then your in a worse predicament...
PostPosted: Sun Mar 27, 2011 8:37 am Up
Thats what you get with cheap nasty pattern parts Wink
Dan-
PostPosted: Sun Mar 27, 2011 8:42 am Up
Cheers guys but no luck so have had to put bottom 1 on and leave it till tomorrow and angle grind the nut off, believe it or not it's an original pug just been on the car for 6years
PostPosted: Sun Mar 27, 2011 8:43 am Up
If its an original Pug one then use the spanner flats Wink
Dan-
PostPosted: Sun Mar 27, 2011 8:46 am Up
Spanner flats?
DeadEyePaul
PostPosted: Sun Mar 27, 2011 8:57 am Up
get a drill bit(for drilling metal) same size as the bolt and drill the B*tard when you get down to the nut it will just fall off
PostPosted: Sun Mar 27, 2011 9:15 am Up
grind it off.
sicskate
Trade Rating: +13
Cut it off with an angle grinder!
307 1.4hdi Smile
Zoomy
PostPosted: Sun Mar 27, 2011 12:00 pm Up
What He Said
It's already broken so it doesn't matter...
...You don't like my opinion? Wait until you hear the ones I keep to myself... Razz
smorgan7
PostPosted: Sun Mar 27, 2011 12:11 pm Up
I had the same problem! Cut the rubber cover off and you will find two flat edges to grip with either a set of pliers or molegrips! Hope that helps you out.
206 independence
