Online Now [502]:
Visitors: 501
Today: 115335
Total: 154925327
Forums › The Car › 206 Talk › Damn thing!
Damn thing!
Forum Index › 206 Talk
Dan-
PostPosted: Thu May 26, 2011 12:12 pm Up
Had my clutch and flywheel replaced today picked car up only to find it still juders as bad! Really annoying what else could be causing it? Any idea's
Thanks Dan
206de
PostPosted: Thu May 26, 2011 12:36 pm Up
Did they replace the thrust release bearing along with the clutch change? Was it a Mr Clutch job?
2005 Obsidian Black GTi 180 | Front -50mm Eibach Suspension | Rear Torsion Bar Lowered -30| SP Grille | Gloss Black Vortex Alloys
Dan-
PostPosted: Thu May 26, 2011 12:43 pm Up
Yeah I've got the old one "/ course not
PostPosted: Thu May 26, 2011 12:45 pm Up
so you haven't get the clutch kit?
Dan-
PostPosted: Thu May 26, 2011 12:51 pm Up
Sorry I meant I've got the old clutch, release bearing, pressure plate and flywheel in my boot, so I take it they used the 1 that came with my Exedy clutch kit
mattievrs
PostPosted: Thu May 26, 2011 4:07 pm Up
Knackered shafts,cv joints,hubs, suspension, engine mounts, gearbox and/or differential,master or slave clutch cylinder. Take your pick mate.
NO LONGER ACTIVE ON THE FORUM
