Online Now [566]:
Visitors: 565
Today: 214537
Total: 149604350
Forums › The Car › 206 Talk › Headlight Ajusters
Headlight Ajusters
Forum Index › 206 Talk
Danny.
PostPosted: Thu Jun 09, 2011 4:13 am Up
May be a silly question,
But will the headlight ajusters from phase 1 headlights fit phase 2 headlights?
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
PostPosted: Thu Jun 09, 2011 4:17 am Up
Yes
Danny.
PostPosted: Thu Jun 09, 2011 4:18 am Up
Awesome. Ta
Dan-
PostPosted: Thu Jun 09, 2011 6:23 am Up
Anothere silly question Smile is there a nack to it because in the past I've broken a few plastic ball joints, is it easier to wind them all way down?
PostPosted: Thu Jun 09, 2011 6:33 am Up
Make sure you wind it so all of the ball joint is out from the adjuster as much as possible. Think this makes the bulb face down iirc. Then twist the whole black unit 90degrees roughly to whatever direction it should go depending on which liight. Here it should pop out enough for you to roughly see which way it then needs to slide out to get the ball to the bigger area where you can get it out without breaking.
