Online Now [200]:
Visitors: 199
Today: 74498
Total: 156594248
Forums › The Car › 206 Problems › Engine cutting out when driving.
James28
PostPosted: Tue Aug 16, 2011 1:49 pm Up
My friend has a Peugeot 206 and has been having problems when driving around with the engine cutting out.
She says it seems to randomly cut out when she's slowing down and going down the gears to stop, when she puts her foot on the clutch.
It's like it stalls and she has to turn the key to restart.
She also said it seems to do it when she's running low on fuel. Not necessarily on the orange light, but when its low.
Don't know if that's related though.
Anyone shed any light on this?
Thanks.
Antknee
PostPosted: Tue Aug 16, 2011 1:50 pm Up
Faulty fuel pump maybe?
James28
PostPosted: Tue Aug 16, 2011 1:56 pm Up
If it was fuel pump would it not just do it completely randomly?
I don't really know I'm not no expert lol.
Just seems weird it only does it when she's changing down gears to slow down, at a junction for example.
And only on low fuel.
James
paulyd101
PostPosted: Tue Aug 16, 2011 3:39 pm Up
I'm having the same problem at the moment. Sounds like the idle control valve/stepper motor. I took mine off and cleaned it. Touch wood it's been fine last day or so. Here is a helpful link.
www.206info.co.uk/Foru...esult.html
Paul 2002 206 GTi Moonstone Blue
James28
PostPosted: Wed Aug 17, 2011 11:34 am Up
Yea that does make sense. could be that I guess.
Would there not be problems at idle as well though. It only happens when slowing down and changing down gears?
James
Linkpad
PostPosted: Thu Aug 18, 2011 3:13 am Up
Mine does it rarely could be dirty Spark plugs/ignition leads or something to do with injectors ? Not sure as mine is an old car... My old 106 used to do the same until i changed the spark plugs etc.. Then worked fine.
Boo
Dan-
PostPosted: Thu Aug 18, 2011 3:25 am Up
im a virgin
give us a shag :P <3
Abzynthe
PostPosted: Thu Aug 18, 2011 3:29 am Up
East Area Rep - Abzynthe
Dan- wrote:
im a virgin
give us a shag Razz <3
wtf?? Laughing
Dan-
PostPosted: Thu Aug 18, 2011 4:00 am Up
Ahaha Damn it, knew I shouldn't have left it open while I went to get a drink Razz
PostPosted: Thu Aug 18, 2011 4:07 am Up
Exactly the same problem is up with my saxo, had it on the drive in pieces for months and have placed lots of parts so hopefully it's gone away. If not I can tell you what I think it's not Laughing
Nimminz
PostPosted: Mon Aug 22, 2011 1:32 am Up
We have the same problem, does it exactly as OP says. we also found it did it if you hold the revs steady at about 2500 rpm :/
Its like when the revs drop, they just drop past idle. Get the warning light and some beeping and that.
Think we are going to clean the ICV, check all the vacuum hoses, see if we can clean the crank position sensor, although i reckon its the coil pack.
Car we have is a 1.4 8v
2.0 8v RWD
James28
PostPosted: Wed Aug 24, 2011 5:53 am Up
Let us know how you get on Nimminz.
James
Lecktorious
PostPosted: Wed Aug 24, 2011 6:20 am Up
Trade Rating: +59
ICV, my 306 does the same when dipping the clutch - just haven't bothered to clean it yet Laughing
'98 Nile Blue 306 GTi 6
ian89
PostPosted: Sun Aug 28, 2011 9:39 am Up
ive had new coil pack and spark plugs new air filter and even had the altenator checked and the car was still reving at what ever it pleased and cutting out so cleaned the throttle body out and i keep having to get out and adjust the throttle cable do the car doesnt cut out but this is now not working the car can be sitting at 2000rpm and when i come to a stop dip the clutch the engine cuts out and its happening every time i stop now and when the rev needle drops its going right down to 0 and sometimes its manages to save its self and sit at 500-300 revs like i say depends how it feels i think... any suggestions?
