Online Now [588]:
Visitors: 586
Members: 1
Today: 120568
Total: 154504606
Forums › The Car › 206 Talk › ppt30 bulbs.
ppt30 bulbs.
Forum Index › 206 Talk
devildriverxii
PostPosted: Fri Oct 14, 2011 1:00 pm Up
So according to this thread...
www.206info.co.uk/Foru...art=0.html
I assumed it was the 509t bulbs, but I just bought 4 of these, they look the same, but the bulbs from the mfd are wedge shaped and the 509t bulbs don't fit.
I have loads of dead bulbs in my speedo too which need replacing but I don't know what bulbs to get Sad
2002 1.6 5dr Black Edition.
PostPosted: Fri Oct 14, 2011 1:03 pm Up
You sure they don't fit Confused www.halfords.com/webap...e=shopping
devildriverxii
PostPosted: Fri Oct 14, 2011 1:07 pm Up
The ones I bought look like this
The ones in my speedo and mfd looks similar, but the lip is thinner, and the plastic holder is wedge shaped, not squared.
PostPosted: Fri Oct 14, 2011 1:16 pm Up
Doesn't the coloured bit come off?
devildriverxii
PostPosted: Fri Oct 14, 2011 3:46 pm Up
It doesn't seem to.
devildriverxii
PostPosted: Fri Oct 14, 2011 4:57 pm Up
So the ones I currently have on the left, and the ones I got from ebay are on the right.
Does this help?
Dan-
PostPosted: Fri Oct 14, 2011 5:04 pm Up
i tried for some LED's spedo light on my old focus and never got them to fit so just popped into my local parts shop got 4 1.2w 12v bulbs for 50p and just pulled the bulb out and replaced it
Dan-
PostPosted: Fri Oct 14, 2011 5:06 pm Up
will hunt fot them now see if they look the same as the ones you got from ebay, i know mine r blue tho
devildriverxii
That seems like a load of p**sing about for some cheap bulbs though, No one seems to know where to get these.
Dan-
PostPosted: Fri Oct 14, 2011 5:14 pm Up
just buy 3 really cheap touches and glue them into the bulb socket off the mfd Razz
PostPosted: Fri Oct 14, 2011 5:17 pm Up
You can buy just the led bulb without the holder, you just pull the old bulb out of the holder and push an led one into the holder, used to be a lot cheaper. I will see if I can find a link but on my phone ATM.
Edit: iirc this type www.ebay.co.uk/itm/10x...6365wt_689
elted
PostPosted: Sun Oct 16, 2011 6:58 am Up
Yes those bulbs just pull out of the holder. Then use your old holders>
