Latest: dreyfalon
Overall: 17121
Online Now [586]:
Visitors: 585
Today: 127318
Total: 97653566
Forums › The Car › 206 Problems › anti roll bar ball joint
206racer
PostPosted: Sat Apr 07, 2012 8:06 am Up
Just came back from mot and got 1 advisory.
slight play in anti roll ball joint.
I have searched for a how to but not found one.can someone link me to it if there is one.Also is it a job i could do or does it need to go to a garage.?
Thank you
hello
Dan-
PostPosted: Sat Apr 07, 2012 8:10 am Up
hey, its a very easy job only need simple tools, i will make you a how to now give me 10 mins
138Andy
PostPosted: Sat Apr 07, 2012 8:12 am Up
ill add a photo and an explanation in 2 minutes
206racer
PostPosted: Sat Apr 07, 2012 8:13 am Up
ok thanks guys
hello
138Andy
PostPosted: Sat Apr 07, 2012 8:15 am Up
ohh yeah XD
206racer
PostPosted: Sat Apr 07, 2012 8:17 am Up
is that not the drop links?
hello
Dan-
PostPosted: Sat Apr 07, 2012 8:23 am Up
Right basically you have the anti roll bar drop links with ball joints on either ends with a nut and you have to keep the ball joint from spinning while undoing the nut, so you have to put either a 5mm allen key or T30 torx bit in the end with a 17mm spanner on the nut, keep the socket held while turning the nut
hope this helps
206racer
PostPosted: Sat Apr 07, 2012 8:26 am Up
so is it the drop links im actually changing and not the anti roll bar?
hello
Dan-
PostPosted: Sat Apr 07, 2012 8:31 am Up
i would have to imagine so, the explanations for drop links vary from tester to tester, at the price they cost i would just change them anyway, i also changed my anti roll bar bushed last month and they only cost me 10 pair from peugeot so they are a cheap change, again a very simple job to do, only need an inverted torx socket and a 18mm spanner to hold the nut above the sub frame
206racer
PostPosted: Sat Apr 07, 2012 8:37 am Up
I had the drop links changed last year,surely they cant have gone already,will get someone to take a look before i start and thanks for the pics and notes.
hello
Dan-
PostPosted: Sat Apr 07, 2012 8:40 am Up
in the years and a half ive had my 180 I've gone through 2 sets, last time i went direct though peugeot
were the ones you fitted cheap ones?
206racer
PostPosted: Sat Apr 07, 2012 8:43 am Up
I didnt do the last ones a garage did it so dont know.I suppose the garage would have bought them from europarts or somewhere like that and not peugeot.
hello
Dan-
PostPosted: Sat Apr 07, 2012 8:46 am Up
ah okay, normally euro cars parts are okay, i like to use there parts when peugeot want to much and have had no problem with anything from there,
206racer
PostPosted: Sat Apr 07, 2012 8:50 am Up
If i can find receipt out might be able to get them changed for free,i presume you get 12 months warranty.If not will go to peugeot and buy from them.
hello
138Andy
PostPosted: Sat Apr 07, 2012 8:54 am Up
get under the car and push the drop link up if you hear it clicking means there's play in them and need replacing Smile
i always buy my parts from peugeot then just pay the garage labour to fit them that way you know they will last and your not getting skiffed Smile
