Online Now [522]:
Visitors: 521
Today: 124372
Total: 156476656
Forums › The Car › 206 Problems › just had a bad accident
Go to page 1, 2, 3, 4  Next
Dan-
PostPosted: Wed May 02, 2012 1:40 pm Up
hello just had quite a bad accident, I'm in need of any help on what i may need to replace!
I've basically smashed off the bottom corner of my sump i noticed right away and turned the car off so have not damaged the internals, all i can think off is i need a new sump but looked on service box and there £360 that seems a hell of a lot to me, will it be a job i can do myself or is it quite an intense job not like undo the 16 or so bolts and it will pull off?
Any help will be great thanks
broadblaster
PostPosted: Wed May 02, 2012 1:48 pm Up
easy enough to do mate as you say undo all bolt pull off then new gasket new sump and bolt back togeather.
just hope its not run long enough to cause any other damage.
on a back road playing
Dan-
PostPosted: Wed May 02, 2012 1:50 pm Up
Thanks for the reply! i really do hope so!
Dan-
PostPosted: Wed May 02, 2012 1:51 pm Up
heres the damage!
broadblaster
PostPosted: Wed May 02, 2012 1:57 pm Up
bloody hell what you hit a curb at high speed ????
Dan-
PostPosted: Wed May 02, 2012 2:00 pm Up
nope is was a damn high half a speed bump!!! with tile at the edges and one of the tiles smashed into the corner and took both the tile out and my sump Sad
Dan-
PostPosted: Wed May 02, 2012 2:01 pm Up
looking into the sump there that black thing what is that? also what would that black pipe be used for that came off ?
broadblaster
PostPosted: Wed May 02, 2012 2:02 pm Up
gutted for you mate. how long did the engine run for after it was hit as will only take a few seconds with no oil to do the main bearings in sorry
PostPosted: Wed May 02, 2012 2:03 pm Up
Good effort there!
broadblaster
PostPosted: Wed May 02, 2012 2:04 pm Up
not 100% sure on the 180 as never had the bottom end apart on one of them but looks like the oil pump and oil pick up pipe
Dan-
PostPosted: Wed May 02, 2012 2:08 pm Up
it ran for for about 5 seconds if that! the oil took about 20 mins to drain out, thats what i thought it looks like but am not sure "/
CPB46
PostPosted: Wed May 02, 2012 2:10 pm Up
The black pipe looks like the oil pick up, would usually have a mushroom shape gauze on the bottom.
Don't go by halves, do you!! Lol
broadblaster
PostPosted: Wed May 02, 2012 2:13 pm Up
was it knocked right off like it is in the pics or was it just cracked and you pulled it apart if it was just cracked then you may be luckey.
PostPosted: Wed May 02, 2012 2:14 pm Up
always use PSA sump; cheap sump will rust away very shortly.
even a secondhand sump is still good as i rarely see corrosion on the sump
Dan-
PostPosted: Wed May 02, 2012 2:18 pm Up
only the corner with what i think is oil temp sensor had come off the other bit i just pulled off, so i don't really know no I'm starting to worry Sad i always use original parts where possible but thats for the heads up Smile
Page 1 of 4
