Latest: Andyblue64
Overall: 17123
Online Now [524]:
Visitors: 523
Today: 77494
Total: 98164689
Forums › The Car › 206 Problems › just had a bad accident
rick-gti
PostPosted: Wed May 02, 2012 11:42 pm Up
Have just sold a sump for £20, if i had known how much they were new id have asked abit more. You should be fine, shouldnt be any internal damage. Mate of mine hit a bolder and smashed his sump on his 306 d-turbo, he drove it about 800 yards with no oil and that was fine.
clio 197sport owner
HDI90
PostPosted: Thu May 03, 2012 12:50 am Up
have a look on service box see if the part numbers match for the GTI and 180
GTI 180
Dan-
PostPosted: Thu May 03, 2012 3:21 am Up
Thanks lee but have just bit the bullet and brought new from pug Sad the 138 and 180 have a slightly diff part number and is £1 price difference, think the total was £360 with gasket sealent, oil probe sensor and sump! Not to bad could have been worse!
PostPosted: Thu May 03, 2012 3:38 am Up
Sold 180 sumps for £30, don't have any left though. If you know what you are doing may end up not being that pricey if you want to do it yourself
rick-gti
PostPosted: Thu May 03, 2012 3:47 am Up
Ive just took one off, quite easy if you have a socket set 10mm and 16mm and torx bits. Hardest part i found was getting the dip stick dissconected. But appart from that was a doddle.
clio 197sport owner
PostPosted: Thu May 03, 2012 5:20 am Up
If anybody knows if the 180 sump is the same as the 138 sump then you can buy my 138 sump.
It's different.
Dan-
PostPosted: Thu May 03, 2012 1:14 pm Up
in need of any advise possible! I've decided to start removing the sump but I'm stuck trying to remove the dipstick tube! how do you get to the torx screw the oil filter housing seems to be in the way what ever i try to do
Andrew
PostPosted: Thu May 03, 2012 2:04 pm Up
Someone should be able to correct me, but could you claim the repair from the council provided you weren't going too fast?
After all, there is no need to put tiles in speed bumps when normal humped ones do the job of slowing people down
My 206 thread
www.detailedbyandrew.com
Necro
PostPosted: Thu May 03, 2012 2:12 pm Up
Them f*****g speedhumps! GRR...
Pug 206 GTi 138 Owner.
xspongerx
PostPosted: Thu May 03, 2012 2:31 pm Up
When I read the title I expected this....
PostPosted: Thu May 03, 2012 2:49 pm Up
Count yourself lucky. This is a bad accident!
Dan-
PostPosted: Thu May 03, 2012 3:06 pm Up
haha, looking at it that way i guess
-Dave-
PostPosted: Thu May 03, 2012 3:15 pm Up
Trade Rating: +36
f*****g hell Lee Shocked
That's my pizza not looking as tasty now.
Ex 206 Owner.
Rob2859
PostPosted: Thu May 03, 2012 3:57 pm Up
Trust Lee...
That is probably what the lamb I hit last night looked like. I cringed at the last rabbit I hit...
rick-gti
PostPosted: Thu May 03, 2012 10:31 pm Up
Replied to your p.m before reading this. You should be able to get to the top torx bolt on the dipstick if you cant get to the bottom one. I had the engine out so thats probably why it was alot easier for me. Mine is a 138 so might be slightly different to the 180.
clio 197sport owner
Page 3 of 4
