Online Now [586]:
Visitors: 585
Today: 185950
Total: 155478522
Forums › The Car › 206 Problems › Few elec questions
Few elec questions
Go to page Previous  1, 2
Danw_VVT
PostPosted: Wed May 09, 2012 5:44 am Up
Any one else?
Dan-
PostPosted: Wed May 09, 2012 6:17 am Up
Check the wire going to the sensor, for 4 months I had the Eml on and had the code read came up as co2 sensor, changed it and 5 miles down the road it came back on, the wires above the gearbox had snapped so wansnt getting power,
Danw_VVT
PostPosted: Wed May 09, 2012 6:54 am Up
The ones from the connector to the sensor are fine I will have to check the rest but they atre tied into the main loom
Dan-
PostPosted: Wed May 09, 2012 7:03 am Up
Mine had a break here
Hope this helps
Danw_VVT
PostPosted: Wed May 09, 2012 7:23 am Up
That's brilliant thanks I'll check there this evening, fingers crossed
CHAOS94
PostPosted: Wed May 09, 2012 10:00 am Up
do what i did i captured a cheater and straped it in my engine bay it goes like the clappers and fuel cost is pretty low
The engine of CHAOS
Danw_VVT
PostPosted: Wed May 09, 2012 10:53 am Up
Er thanks for that?
Andrew
PostPosted: Wed May 09, 2012 4:45 pm Up
Have you changed the pre cat sensor? Would that also cause this problem, anyone?
My 206 thread
www.detailedbyandrew.com
Danw_VVT
PostPosted: Thu May 10, 2012 12:41 pm Up
No it's not the pre cat as the fault code is for the bank 1 sensor 2.
Still going through the short to battery to check for damage hmmmmm
Page 2 of 2
