Latest: sparrowdclxvi
Overall: 17139
Online Now [224]:
Visitors: 223
Today: 29968
Total: 113101362
Forums › The Car › 206 Problems › rear suspension top fixing
Go to page Previous  1, 2
chambie1980
PostPosted: Sun Nov 25, 2012 3:36 pm Up
thanks pal youve been more than a great help ( providing pics when I couldn't ) I've saved this pic to show my mechanic so were on same page. can't thank you all enough. really grateful
chambie1980
bezford
PostPosted: Sun Nov 25, 2012 8:50 pm Up
if your neighbours sayin get your wallet out its maybe a bit cold for him as it soundfs like he doent want to do it??????????
R.HYDE
chambie1980
PostPosted: Tue Nov 27, 2012 12:54 pm Up
To to let you all know I've had suspension arm tightened but problem still persists. Think I've found the problem though... A plastic cover in the wheel arch ( * feel stupid face * lol ) would you think drilling in to the arch and screw it down would be ok or should I get someone to do it properly
chambie1980
Dan-
PostPosted: Tue Nov 27, 2012 2:56 pm Up
what side is it? 1 more thing you could try is lay under the back of the car and get somebody to push down the back while you feel and listen for the noise it worked for me to identify the loose bolt
chambie1980
PostPosted: Thu Nov 29, 2012 1:38 pm Up
Driver side back end pal, had a look and its spacers i need as the wheel is very close to the inner of the arch and and can see where its rubbing ( probably shot 10 - 20 mm )
chambie1980
Dan-
PostPosted: Thu Nov 29, 2012 1:54 pm Up
you not running standard peugeot wheels then?
Page 2 of 2
