Online Now [220]:
Visitors: 218
Members: 1
Today: 45175
Total: 155763653
Forums › The Car › 206 Talk › Is there a special tool needed to remove rear axle?
Forum Index › 206 Talk
Simmo
PostPosted: Fri Jan 11, 2013 6:32 am Up
I recently saw on a YouTube video that there is a large star key that I may need to remove my axle. Can someone confirm this???
1.1 silver style www.206info.co.uk/Foru...52484.html
Mattie-RS
PostPosted: Fri Jan 11, 2013 6:37 am Up
I wouldn't call it a special tool
You don't have to do this but it's what I did, just use a normal socket that fits hammer it on and it will work.
iainlovatt
PostPosted: Fri Jan 11, 2013 7:02 am Up
nope my toolkit from halfords did the job! Only took 25 mins too!
(My Garage)
Simmo
PostPosted: Fri Jan 11, 2013 7:59 am Up
5 door and 3 doors won't have different axles will they???
Dan-
PostPosted: Fri Jan 11, 2013 8:20 am Up
all 206's use the same axles,
lenbt
PostPosted: Fri Jan 11, 2013 2:22 pm Up
Female torx socket?
PostPosted: Fri Jan 11, 2013 2:30 pm Up
E socket
chuckstar34
PostPosted: Fri Jan 11, 2013 4:05 pm Up
I thinks its an E17. Try not to ram a socket over the bolt head. I agree it might work , but if the bolts are in solid, as most are, youll round it off and then you really are in poo street. I know.... I did it. Luckily I got away with it after getting correct E Socket but i shat my self when I span the head off. SO get the correct one...its really worth it.
Chuckster.
