Latest: S2cgm
Overall: 17178
Online Now [972]:
Visitors: 971
Today: 28336
Total: 136049730
Forums › The Car › 206 Problems › Squeeling belt on full lock?
PezHdi
PostPosted: Mon Nov 24, 2014 5:42 pm Up
Hay guys.
Not very often I ask for help as I Can normally sort most my self but this time I would like some help just to sort out more of an annoying situation not a problem.
Basically when I'm turning the wheel on the car to full lock I'm getting a squeeling noise from my belt.
When this happens I notice that the lights on the dash and headlights dim slightly.
I'm guessing this is going to be because the car is loaded up and most of you will say the battry is on it's way out.
Iv tested the battey and it says it has a good life on my battey reader.
So want could he causing this?
Alternator?
Earlier on in the year I have replaced the fuel pump with a bigger one off a 2.2 hdi and removed the aircon, found a shorter belt which fit and fitted that.
Other than that I can think of anything else.
Any help would be kindly taken
Regards Pez
EXL Pez
PostPosted: Mon Nov 24, 2014 6:38 pm Up
Sure it's the belt and bit the pump?
PezHdi
PostPosted: Tue Nov 25, 2014 1:23 am Up
Do you think it maybe the power steering pump?
EXL Pez
Vexs
PostPosted: Tue Nov 25, 2014 1:33 am Up
Was my first thought & had an identical problem when I first picked up my car which was solved by doing the pump and belt together.
If the above is the case then the lights shouldn't be dimming because of it surely.
My GTI 180
My Old 1.4 8v
PezHdi
PostPosted: Tue Nov 25, 2014 5:55 am Up
I will have another look today.
Is there any way I can test the alternator as well?
EXL Pez
ukskater01
PostPosted: Tue Nov 25, 2014 7:14 am Up
I had the same problem on a vito van, turned out to be the alternator, putting more stress on the power steering pump
PezHdi
PostPosted: Tue Nov 25, 2014 11:37 am Up
Okay cheers for your in out guys.
Had a look today and I can't see anything else that's causing it.
EXL Pez
PezHdi
PostPosted: Wed Dec 03, 2014 5:25 am Up
Okay update.
Been busy this week so not really had chance to look.
does anyone no what type of power steering fluid the 2.0 hdi uses?
It needs topping up and I'm thinking maybe il change the lot while I'm doing it?!
EXL Pez
Oafie
PostPosted: Wed Dec 03, 2014 6:00 am Up
Any power steering fluid will do, just don't use LHM, they fluid they put in old citroen's, the ones with the hydraulic suspension.
PezHdi
PostPosted: Wed Dec 03, 2014 10:02 am Up
Okay car is topped up. But it's still squeeling.
Hmmmmmmmm
EXL Pez
PostPosted: Wed Dec 03, 2014 10:06 am Up
Changed the aux belt? Is it actually tight?
PezHdi
PostPosted: Wed Dec 03, 2014 12:09 pm Up
Yeah mate changed about a month ago when I removed the air con and the belt felt really really tight but it's worth checking.
does anyone no the part number for a non aircon 2.0 hdi.
Regards.
EXL Pez
PostPosted: Wed Dec 03, 2014 1:36 pm Up
Can you twist the belt past 90 degrees?
PezHdi
PostPosted: Wed Dec 03, 2014 1:40 pm Up
Il have a look when I finish work. Unless I have time before hand Smile
EXL Pez
