Online Now [520]:
Visitors: 519
Today: 114932
Total: 128488616
Forums › The Car › 206 Problems › Bleed screws.
Bleed screws.
Danweider
PostPosted: Wed Nov 22, 2017 9:36 am Up
Hi lads, I am currently after x4 bleed screws, x2 for the calipers, x2 for the rear drums, on my peugeot 206 1.4. I cannot find where to buy them for the life of me. Any suggestions?
Dan
gazza82
PostPosted: Wed Nov 22, 2017 11:07 am Up
Dealer? Peugeot or Citroen will be able to get them .. and don't assume they are more expensive .. I've bought new parts from them cheaper than I could find on fleabay!
PostPosted: Wed Nov 22, 2017 12:09 pm Up
Brakes International
Danweider
PostPosted: Wed Nov 22, 2017 5:57 pm Up
Cheers guys! Went to my local dealership, got x4 on order for £18! Happy days.
PostPosted: Thu Nov 23, 2017 3:27 pm Up
£18 for 4 bleed screws? Ouch....
Danweider
PostPosted: Fri Nov 24, 2017 12:06 pm Up
I know quite deer. But this is another thing I need to come on to..the rear bleed screws in the hubs, are seriously stuck, I have tried soaking in WD40, and with a pair of mole grips, trying to wiggle them free..no luck. I have gone out and got some plus gas lubricant which I will be trying, also I am going to try heating them up if the plus gas, fails. Any other ideas? I cannot get a spanner on there as they just keep slipping.
gazza82
PostPosted: Fri Nov 24, 2017 3:16 pm Up
Now I know why one of our rear caliper bleed screws was snapped off ..
PostPosted: Fri Nov 24, 2017 5:12 pm Up
Use a proper flared brake union spanner and apply plenty of heat first.
Danweider
PostPosted: Fri Nov 24, 2017 6:43 pm Up
Gazza, i think the only solution for that is a new caliper, when needing to bleed, although my college tutor (studying vehicle mechanics) said you can get away with just bleeding the other points it should be fine.
Lee, i dont have a flare spanner, would mole grips do the job? Being careful of course.
Thank you for the help Smile
Dan.
Indigo_GTI
PostPosted: Fri Nov 24, 2017 11:36 pm Up
try a socket (best fit, ie hexagon only, not a double hexagon style socket) and a bit of heat as suggested. Stainless bleed screws are a good investment, particularly if you plan the keep the car for a while.
gazza82
PostPosted: Sat Nov 25, 2017 12:45 am Up
Dan.
Sold the CC! Not my probkem now Wink
Danweider
PostPosted: Sun Nov 26, 2017 1:16 pm Up
I've tried heating them with a blowtorch, using plus gas lubricant, no avail. It's completely rounded now. Anyone have any last minute tips before it goes to the garage?
Indigo_GTI
PostPosted: Tue Nov 28, 2017 12:22 pm Up
hammer on a socket that's a bit too small, might be enough to grip it. If it does come off, its easy enough to get the bit out of the socket with a metal punch
