Latest: DanDan17
Overall: 17128
Online Now [130]:
Visitors: 129
Today: 29284
Total: 100427445
Forums › The Car › 206 Problems › Locking wheel nuts
Locking wheel nuts
Dan-
PostPosted: Fri May 20, 2011 1:01 pm Up
I've got quite a big problem, when the garage attempted to do my clutch few weeks ago, they put my wheels on with air gun, and done locking nut with them too, and rounded the pins of the stud now rhe key spins on it, tried hammering a socket with no luck just the top off, I'm really stuck for what to do
iainlovatt
PostPosted: Fri May 20, 2011 1:06 pm Up
use a smaller socket maybe! Crying or Very sad
(My Garage)
206de
PostPosted: Fri May 20, 2011 1:11 pm Up
May need a nut being welded onto it and a long breaker bar to get it off. This is what happened to me too but in my efforts to get it off it sheared off and I had to get it welded off!! Garage I took mine to seemed to get alot of jobs like that, so done it fairly quick and protected the wheels too!
2005 Obsidian Black GTi 180 | Front -50mm Eibach Suspension | Rear Torsion Bar Lowered -30| SP Grille | Gloss Black Vortex Alloys
Surfer333
PostPosted: Fri May 20, 2011 1:18 pm Up
You can buy a 'top thingy' Sorry can't remember what they're called, anyway this bites onto broken nut bolts and then use a socket set wrench to get broken one out.
This happened to me on old wheel locking nuts, as the locking wheel key one was not in the 206 GTi when I bought it. The garage that got the old locking wheel nuts off did this in no time at all.
View user's profile Visit poster's website AIM Address MSN Messenger
Dan-
PostPosted: Fri May 20, 2011 1:29 pm Up
thanks for the replies guy, gonna try and get it welded i recken then. well heres a pic of whats happened
206de
PostPosted: Fri May 20, 2011 1:34 pm Up
Yeah thats exactly what mine looked like when it sheared off!!
Just make sure where you go they protect the bolt holes and mask the wheel up Smile
PostPosted: Fri May 20, 2011 1:36 pm Up
Drill & easy out, there soft as s**te Wink
In future dont let cowboys work on your car Laughing
Dan-
PostPosted: Fri May 20, 2011 1:41 pm Up
ah thats good then, thanks again i will ask at work tomoz see if they can weld a bolt/nut on, failing that ill drill as i need it off by weds because im getting my clutch/flywheel fitted :D, and they'll need the pass front wheel off
michaelbishop
PostPosted: Fri May 20, 2011 1:48 pm Up
What He Said
V important you tell them to protect the wheels. It happened to my mam's old car, they got the nut out no problem but melted the area surrounding the nut on the alloy and it looked awful!! Evil or Very Mad
The Journey, The Garage,
