Latest: Andyblue64
Overall: 17123
Online Now [84]:
Visitors: 83
Today: 20756
Total: 98024756
Forums › The Car › 206 Problems › gti 180 feeling slugish
shell-vt
PostPosted: Mon Aug 29, 2011 5:08 pm Up
Trade Rating: +46
well my gti 180 hasnt been run for 2months so got it started today (battery was near dead,) anyway took it for a quick run but it felt really slugish on throttle untill it was warm.... (its had new oil plugs oem filter)
anyone had this problem
york 16,3
NICKST
PostPosted: Tue Aug 30, 2011 2:46 am Up
What make Plugs did u use?
Dan-
PostPosted: Tue Aug 30, 2011 3:20 am Up
mines also sluggish from cold, lerches sort off until warm, ive just put i down to a faulty lambda sensor, as my eng managment lights, and that oxygen sensor flashed up on the diagnostics machine,
Have you got any lights on?
shell-vt
PostPosted: Tue Aug 30, 2011 3:52 am Up
Trade Rating: +46
i havent any lights on ... bosch super 4s
york 16,3
Slowride
PostPosted: Tue Aug 30, 2011 4:07 am Up
Maybe it's your coil pack, it was the problem on my car last week. Also changed the spark plugs, but you already did. At the end mine ran on 3 cilinders when it was warm, with fault code P0351.
shell-vt
PostPosted: Tue Aug 30, 2011 4:12 am Up
Trade Rating: +46
ive never had it read as yet, but i am waiting for a new coil pack anyway its ok when warm also tickover is perfect, its just feeling as if it doesant want to pull from cold, but will rev ok with clutch in
york 16,3
Quarmbo
PostPosted: Tue Aug 30, 2011 4:35 am Up
vvt solenoid?
Ford SportGay-A
shell-vt
PostPosted: Tue Aug 30, 2011 4:59 am Up
Trade Rating: +46
clean or get new???
york 16,3
Dan-
PostPosted: Tue Aug 30, 2011 5:01 am Up
Also the same as mine "/
PostPosted: Tue Aug 30, 2011 5:02 am Up
shell-vt wrote:
clean or get new???
Try cleaning it first Wink
sri16v
PostPosted: Sun Sep 04, 2011 10:21 am Up
I thought all 180's ran bad from cold? mine always has in the 2 years Ive owned, very hesistant and juddery. Once warm drives fine.
2004 GTi 180
Mattie-RS
PostPosted: Sun Sep 04, 2011 11:41 am Up
Mine is the same, although not a 180 but still a 2.0
