Latest: DanDan17
Overall: 17128
Online Now [417]:
Visitors: 416
Today: 9194
Total: 100678609
Forums › The Car › 206 Problems › Clutch Issues
Clutch Issues
danhodson
PostPosted: Fri Oct 07, 2011 6:10 am Up
So over the last couple of days my biting point has been extremely inconsistent, to the point where the actual clutch gave up and started slipping, rendering the car undrivable.
I had AA roadside recovery and was recovered to a garage. I've had the clutch replaced to the tune of £390... £120 parts (the rest labour) I think thats pretty steep to be fair.
The question is, my clock says 66,000 miles, how long do clutches usually last, as I'm starting to think this isn't genuine mileage.
Dan-
PostPosted: Fri Oct 07, 2011 6:33 am Up
They vary depending on how you drive the car, all I know is that when my 180 was on 43000 when I had mine done noticed a stamp on the old kit that stated it was made in 2008 and meaning it only don't 23000 miles on. Clutch in just under 3 years
kit325
PostPosted: Fri Oct 07, 2011 6:36 am Up
Depends on your driving style and where normally you drive (more wear and tear on city driving).
Make sure u put in branded clutch kit set like LUK or valeo, might cost u more compare to some cheap clutch kit but will save u a lot more on long run consider labour charge is very expensive in uk.
I would say 300+ consider a reasonable charge with branded clucth kit.
kit
LiamGTi180
PostPosted: Fri Oct 07, 2011 10:33 am Up
One of the vans at my work needed a new clutch after 20,000 miles. As above it depends on how its driven.
Dutch-HDi
PostPosted: Fri Oct 07, 2011 10:42 am Up
ive pulled clutch's from cars that have dont 200,000 and then some after 10 to 15 k
What He Said
really depends how the cars driven, id say look at the old clutch see if its worn evenly Wink
206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955)
PostPosted: Fri Oct 07, 2011 11:24 am Up
anything from 1miles to over 150K miles
Pug-Lee-2011
PostPosted: Mon Oct 10, 2011 6:31 am Up
Trade Rating: -1
just be gently on her lol
LilLew
PostPosted: Mon Oct 10, 2011 8:52 am Up
i paid £250 cash to have a clutch kit fitted on my 180 and that was at 69,000 i only got the car at 63,000 i have it 3 months i do alot of driving in 1 year i have done 30,000
2003 Pug 206 2.0 GTI 180
MrrNoName
PostPosted: Mon Oct 10, 2011 9:29 am Up
Whats been said above is correct, ive seen worn out clutches on 20,000 miles. Ive also seen a 307 with 180,000 miles still using the original clutch!
