Forums › The Car › 206 Talk › gearbox mount |
Posted: Thu Oct 13, 2011 2:44 pm |
Posted: Thu Oct 13, 2011 2:51 pm |
Yes and the two other bolts as well.
Posted: Thu Oct 13, 2011 2:57 pm |
ah brillaint thank you, is the part called a right engine mount or a gearbox mount as im having trouble finding one called gearbox mount, could you confirm for me this is what i need to buy
www.eurocarparts.com/e...c80&000461
Posted: Fri Oct 14, 2011 5:42 am |
I would say it's a gearbox mount.
