Online Now [1042]:
Visitors: 1041
Today: 101351
Total: 150410257
Forums › The Car › 206 Problems › What is this?
What is this?
LiamGTi180
PostPosted: Tue Nov 01, 2011 7:38 am Up
Ok so i come to change my induction kit from the one the previous owner had put in. i find this hanging loose under the car and just pulled it out. there is something else that is also hanging. what is this and what does it connect to away from the air filter?
Dan-
PostPosted: Tue Nov 01, 2011 8:20 am Up
There you go mate that should clear things up for you abit
LiamGTi180
PostPosted: Tue Nov 01, 2011 8:35 am Up
so if im fitting an aftermarket intake what do i do with everything below this point? it seems wasted when its disconnected?
Dan-
PostPosted: Tue Nov 01, 2011 9:21 am Up
What I done was remove bumper and arch liner for better access then unbolt the motor type thing and remove the vacume hoses then just pulled to unhook it, putting it back on Is harder aha
LiamGTi180
PostPosted: Tue Nov 01, 2011 9:37 am Up
what is number 14? thanks lee
Dan-
PostPosted: Tue Nov 01, 2011 9:48 am Up
Should be attached to the bottom half of the intake, just remove the hoses and yhat all
LiamGTi180
PostPosted: Tue Nov 01, 2011 9:54 am Up
sorry i meant thanks dan. very helpful mate
