Latest: evert
Overall: 17112
Online Now [102]:
Visitors: 101
Today: 747
Total: 93749267
Forums › Tuning, Modification & Legal › Project Cars › ZiAn's pride & joy 206GTi (EW12J4 in progress) pg.9
Go to page Previous  1, 2, 3 ... , 11, 12, 13  Next
vxedcc
PostPosted: Thu Sep 17, 2015 3:52 am Up
Hi, what did you decide to do about the balancer shafts?
114.3 - 180bhp 1.9 8v (depends which readout you believe)
Ew hybrid in progress...
drmo
PostPosted: Fri Sep 25, 2015 4:27 pm Up
=ZiAn= wrote:
@Usher, when the mechanics get it all together Smile Should be in about a month or two as they a re a bit busy... But if I've waited for the last 4 years I can wait a few months more Smile
@206gt160, 15" Citroen c5 if I'm not mistaken and they were super light (don't quote me but i believe they were around 6kg?).I'll ask the owner of the wheels when I get to see him Wink
Around 4.6kg more precisely Smile Need another set? I have like 4 sets Very Happy
We threw them out as they are not needed.
www.enigma-motorsport.si
www.facebook.com/Enigm.../timeline/
heyziq
PostPosted: Sat Sep 26, 2015 3:13 am Up
how much power it running, is 2.2 more worth to put rather than gti180 engine :),
heyziq.com
drmo
PostPosted: Sun Sep 27, 2015 2:53 pm Up
Not built yet. It will have a gti180 head with catcams 805. More potential with bigger displacement, but we will see.
drmo
PostPosted: Tue Oct 20, 2015 3:22 pm Up
Some progress regarding the engine:
drive.google.com/uc?ex...0ZkVkU4M2c
drive.google.com/uc?ex...05Td2ZnMFk
drive.google.com/uc?ex...DZCUWQ5Wkk
drive.google.com/uc?ex...lI4b0hUZFk
drive.google.com/uc?ex...Gt5YUIzOTQ
=ZiAn=
PostPosted: Sat Nov 07, 2015 6:35 am Up
Thanks for the update Drmo Smile I haven't had a lot of time lately, so I haven't been posting much so here are a few more pics:
ZianDesigns - Website designs
=ZiAn=
PostPosted: Sat Feb 13, 2016 3:40 am Up
I think there's something missing.. Very Happy
Old one is out:
New one waiting on the stand to be installed
PostPosted: Sat Feb 13, 2016 9:17 am Up
Excellent. I'm surprised you still have the air conditioning pump still in there. Would be interesting to see how the EW12 likes to rev with it being a longer stroke than the EW10.
tRiCk
PostPosted: Wed Feb 24, 2016 8:56 am Up
I've had mine in for sometime now BTW, did you notch your pistons for valve clearance, the valves on the 180 open more than the ew12s. I did on mine but I also kept the balancing shafts,
tRiCk
PostPosted: Wed Feb 24, 2016 8:57 am Up
No egr on mine either as I'm still using gti180 ECU
drmo
PostPosted: Mon Mar 14, 2016 3:46 am Up
I Timed the cams in a way that there is enough clearance when the cam is fully advanced so no notching the pistons needed. The cams are Catcams 4901805, so much more lift than the original GTI180 cams. The springs and retainers are also from Catcams.
The Balancing shafts were deleted because the rev limit will be higher and there is possibility of oil starvation and balancing shaft seizing.
@tRiCk: did you get it remaped or at least on a rolling road?
=ZiAn=
PostPosted: Thu May 05, 2016 3:02 pm Up
So things are moving along, the engine is in the car and should be getting the new loom, ECU and tune in the following weeks.
Here's also a short video from last years track session. Had to slow down in the middle, due to a "funny" feeling in the steering though it luckily turned out to be fine Smile
www.youtube.com/watch?v=JsQfc8j51ls
Sim
PostPosted: Fri May 06, 2016 6:14 pm Up
Thanks for the vid! Will serve me as a benchmark to hit of a well balanced rebuilt engine -- you gotta hear those 16 valves purrrrrroaring! Nom Nom Droolage!
What was that steering wheel feeling out of interest?
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
=ZiAn=
PostPosted: Sun May 08, 2016 3:28 am Up
It was like driving on gravel etc. It's been a while since the last time I was out on track and forgot that the tires will pickup allsort of crap, specially if you're on the outerparts of the racing line Laughing
Can't wait for the new engine though, that will be a lot more fun Smile
oldskoolz
PostPosted: Mon May 09, 2016 12:36 am Up
Doesn't seem to rev any slower than the 138. Well not that I can notice, I done the conversion about 6 months ago. Still running 138 ecu atm hoping to fit a piggyback to properly control the vvt as its just on a switch atm.
Black 206 Gti. Soon to be 2.2
Page 12 of 13
