Latest: lio94
Overall: 17181
Online Now [233]:
Visitors: 233
Today: 877
Total: 141556285
Forums › The Car › 206 Talk › Where can I get Anti roll brushes
Foz369
PostPosted: Sun Mar 11, 2012 2:32 pm Up
Where can I get anti-roll brushes from cheaply and reliably?
What do these actually do anyway?
sig removed due to size
lmilligan
PostPosted: Sun Mar 11, 2012 2:52 pm Up
Go to Peugeot
Foz369
PostPosted: Sun Mar 11, 2012 2:57 pm Up
which ones do I need to buy, my car is 51 plate LX 1.4L?
Dan-
PostPosted: Sun Mar 11, 2012 3:03 pm Up
5094 82 - peugeot part number £11.86 +vat
sure if I'm wrong someone can confirm
Foz369
PostPosted: Sun Mar 11, 2012 3:20 pm Up
Where can i get them from?
Bummers
PostPosted: Sun Mar 11, 2012 3:21 pm Up
use duct tape to apply one either side of your car, reduces body roll and cleans the road as you go! Very Happy
Alternatively bushes are rubber grommets that allow a bit of flex and movement. When they wear you get excessive play in the joint.
You can see from this image, when the rubber begins to wear you'll get the excess play and eventually knocking/banging.
2003 206xsi 1.6 16valve
Foz369
PostPosted: Sun Mar 11, 2012 3:25 pm Up
Ok, does the mop go out of the hole in the back? Very Happy
Thats quite cool, Where can I get the right ones from?
Bummers
PostPosted: Sun Mar 11, 2012 4:15 pm Up
Peugeot dealer/parts dept should be able to supply them. Always best to get OEM, I've found it false economy to get cheap pattern parts from motorfactors, they just never last as long.
