Online Now [1649]:
Visitors: 1647
Members: 1
Today: 402477
Total: 153798821
Forums › The Car › 206 Problems › developed a slight problem
Dan-
PostPosted: Sat Mar 17, 2012 5:04 pm Up
I fitted my coil overs today and on checking everything i noticed i had a wobble in both my front wheels when held at 9-3 but nothing when held at 12-6 i can see nothing lose moving behind the hub when someone else does it seems to be in front the abs rings, passenger side is worse than the drivers tho slightly, i was thinking wheel bearing but every one I've change I've had 12-6 motion aswell just seems weird, i get nothing through the steering no noise when driving, its really puzzling me
Any suggestions what it could be or what to check will be of help
Thanks Dan
PostPosted: Sat Mar 17, 2012 5:36 pm Up
Have you tightened the nut back up behind the strut on the bottom of the hub?
Dan-
PostPosted: Sat Mar 17, 2012 6:01 pm Up
yeah to the haynes manual toque setting "/
marrygold75
PostPosted: Sun Mar 18, 2012 2:28 am Up
i did my bearings on the passengers side last month and i only had play at 3/9 .
have a nice day
Dan-
PostPosted: Sun Mar 18, 2012 1:20 pm Up
ah thats good then will order 2 new ones then Smile thanks
Dan-
PostPosted: Wed Mar 28, 2012 12:36 pm Up
had a quick look just now with the wheel off the floor i seem to have play in my track rod end ball joint I'm guessing thats where my problem lays! also will euro car parts be good enough as there the only way ill have them by the weekend?
