Online Now [1220]:
Visitors: 1219
Today: 84610
Total: 151870107
Forums › The Car › 206 Problems › Multiplex wiring Vs Aftermarket headunit :(
MattP182
PostPosted: Wed Oct 03, 2012 6:51 am Up
Hey everyone im new to this forum, I've searched for this topic but didnt really find anything so I was wondering if you could help? Smile
In my previous car I had a sony headunit , unfortunatley that got wrote off, last week I bought a 2006 206 with some big plans for it, however after taking it to halfords to get the unit fitted in my car ( i didnt realise how easy it was to fit - quickest £29.99 ive ever spent lol Sad ) I realised that once i started the engine the clock stopped and the 'left drivers door open' would freeze on the center display... after realising this i went back to halfords.. they said that it was because the 206 had a multiplex wiring setup and they said i should go to peugeot and see if they can help , anyway off i went to the local peugeot garage....and they quoted me £235!?! really?? is this the only option I have if I want a better stereo lol? im just wondering if anyone knows if there is a much cheaper way to bypass the system etc? any help would be much appreciated! sorry if I have baffled on haha
Matt
PostPosted: Wed Oct 03, 2012 7:02 am Up
Sounds like they've disturbed the MFD connector or wiring, or mis-connected the stereo, or knackered the MFD. (Multi Funtion Display)
Tried dis-connecting the stereo?
You could also try re-booting the BSI just in case that helps.
Abzynthe
PostPosted: Wed Oct 03, 2012 7:12 am Up
East Area Rep - Abzynthe
I think a BSI reboot may be the best first option to try. Smile
MattP182
PostPosted: Wed Oct 03, 2012 7:16 am Up
thanks for your help Smile just taken it back to halfords as they offered a refund for the fitting however they refitted the old stereo..and bam... everything worked perfect like normal :S does this mean i wont be able to fit a aftermarket headunit without forking out £235, thats rubbish lol! - oooo also another problem when i had my sony headunit fitted was that when I had taken the key out of the egnition the stereo wouldnt automatically turn off Sad
Dan-
PostPosted: Wed Oct 03, 2012 9:37 am Up
The bit about it staying on is normal as it turns off after about 30 seconds when the bis shuts down
PostPosted: Wed Oct 03, 2012 10:04 am Up
Either reboot the BSI unit correctly OR unplug the MFD for a few seconds then reconnect it.
The easier option would have been to go to a Peugeot / Citroen main dealer & spend £8.98 at the parts counter on the multiplex ISO radio adaptor harness then simply fit your own radio.
MattP182
PostPosted: Wed Oct 03, 2012 12:04 pm Up
Thankyou mr Bsi ... well everything works fine when the standard factory radio is fitted... so i dont think il have to reboot the bsi..if i understand correctly because, there's nothing wrong with it, the connection just seems to mess up when the new radio is fitted, i will be on my way to get one of them multiplex ISO radio adaptor... £8.98 sounds a lot more reasonable haha!
thanks for everyones help Smile
skard
PostPosted: Wed Oct 03, 2012 4:58 pm Up
I take it you have the single line MFD?
Swapping it out for a triple line display means you'll never get this freezing again, and it looks way better.
You can also swap over a pin on your Sony loom so that the HU goes off with ignition, and not when the BSI goes to sleep.
skard
PostPosted: Wed Oct 03, 2012 5:00 pm Up
For the pin swap so HU goes off with ignition on muxed cars, see this www.206info.co.uk/Foru...=loom.html
