Posted: Fri Nov 23, 2012 4:09 pm |
Recently bought a 206 gti on a 52 plate, its done about 96000 miles, 3 previous owners , there's a knocking in the engine, garage said it could be a hydraulic tap?? they said to start with an engine flush and oil change and run for a day.
any other ideas what it could be?? is the engine flush the way forward?
cheers
stu
Posted: Fri Nov 23, 2012 4:11 pm |
forgot to say, no warning lights of any kind on dash etc
cheers
Posted: Fri Nov 23, 2012 4:55 pm |
Main (big end) bearings could be shot.
Posted: Fri Nov 23, 2012 5:06 pm |
They is a common fault on these it in the manifold u have to take it off and get it tack welded inside
Posted: Fri Nov 23, 2012 5:09 pm |
the bottom end on the 180 engine is rather good as i managed to smash my sump while driving, had no damage to the bearing when i stripped it alll down
as mentioned check the manifold, it used to wind the fu*k out of me when i had my 137 a few years back! hold the car at 4000k revs see if you can hear it!
Posted: Fri Nov 23, 2012 5:12 pm |
this site helped me out abit when i 1st got mine!
worth checking the fix, helped cure another anoying noise on mine
206gti.net/enginecover/
Posted: Sat Nov 24, 2012 5:00 am |
had someone look over it, said it could be the camshaft (high end), it had no oil in when i picked it up so could be that, also said the compression valve could be f***ed, it will need a compression test.
anyone familiar with these?
cheers
