Online Now [786]:
Visitors: 785
Today: 243617
Total: 150542170
Forums › The Car › 206 Talk › Will normal coilovers for a 206 fit a gti
Forum Index › 206 Talk
kenzie
PostPosted: Tue Nov 27, 2012 4:17 pm Up
I ask this as I'm looking to get some coilovers for my gti and on ebay there are only 9 different auctions where as of you just type 206 coilovers you get loads of choice and some good deals. Is the because there for a gti and any coilovers for a 206 would fit anyway model.
Red 206 GTi
Revenge is like a ghost. It takes over every man it touches. It's thirst cannot be quenched, until the last man standing has fallen. The world's men of action will look and wonder...how it came to this. You may be able to destroy me, but the beast will eventually come for you
Dan-
PostPosted: Tue Nov 27, 2012 4:29 pm Up
in simple term yes they will, although not sure if it applies with coilovers, every model has a different weight engine so you get different spring rates, i know it does with lowering springs
kenzie
PostPosted: Tue Nov 27, 2012 4:41 pm Up
Yeah ok sounds good then Smile see if any one else nows any info
Red 206 GTi
PostPosted: Tue Nov 27, 2012 5:18 pm Up
They will fit, but might be a bit stiffer if the coilovers manufacturer fits higher LB springs for the extra weight
But main point, they will fit
anton1989
PostPosted: Tue Nov 27, 2012 5:19 pm Up
Trade Rating: +16
As above they will fit, but most brands would use different springs depending on what engine you have.
I doubt cheap ones do though
Dan-
PostPosted: Tue Nov 27, 2012 5:27 pm Up
I know when I brought my avo coilovers I got the choice, I went for the 2.5 race I/D as my car was used on track, wernt to bad on bunny roads either as you could turn damping on soft Smile
