Online Now [185]:
Visitors: 184
Today: 36312
Total: 143104770
Forums › The Car › 206 Problems › Fixing rear view mirror
fan168
PostPosted: Mon Nov 26, 2012 10:24 am Up
Any suggestions on how to fix my rear view mirror back to the windscreen? Have the automatic wipers option if that makes a difference. Tried double sided tape and super glue but its just not holding. Given its quite cold at the moment that could be causing the glue not to set properly.
ta
PostPosted: Mon Nov 26, 2012 10:27 am Up
Go ask at your local windscreen repair place & slip the lads a couple of drinks Wink
roscoe
PostPosted: Mon Nov 26, 2012 10:29 am Up
Whatever you do, don't use Araldite or similar two-part epoxy. Strong double sided sticky pads should do the trick, other methods will either break the screen or fall off.
Tip - Use a hairdryer to heat the pad up prior to affixing it to the screen, it greatly enhances the adhesive and subsequently, the bonding time is reduced. Still, it's a good idea to firmly hold it in place for 2/3 mins after the initial placing.
Used to own the 206 pictured above
M sport BMW E90 - Gone Sad
Now own Audi A5 Sline Smile
fan168
PostPosted: Mon Nov 26, 2012 10:33 am Up
Any suggestions on where to purchase strong double sided tape? The one's I tried were all weather one's designed for fixing number plates. They seem quite sticky but just wouldn't hold. Didn't think about heating with a hairdryer but will give that a go.
roscoe
PostPosted: Mon Nov 26, 2012 10:38 am Up
Any general DIY hardware store should sort you out. I used number plate adhesive pads it done the job. The weather will have a big part to play as its so darn cold.
Dan-
PostPosted: Mon Nov 26, 2012 1:42 pm Up
number plate is good used it when mine used to fall of my silver gti
DREWDEN
PostPosted: Mon Nov 26, 2012 4:39 pm Up
Try autoglass normally do it for free, done mine in the past. Razz
206 2ltr Hdi glx 53 plate
PostPosted: Tue Nov 27, 2012 11:44 am Up
Wasting your time, they ignored me when I mentioned this earlier Whistle...
fan168
PostPosted: Wed Nov 28, 2012 11:13 am Up
Won’t have time to retry with the double sided tape until the weekend but can anyone confirm if it’s an MOT failure not to have the rear view mirror present? I’ve seen a lot of small vans on the road that just have the two wing mirrors so would assume its road legal not to have one but are the rules different for passenger cars? TBH I have been driving around for a few days now and am kind of getting used to not having one. Was a bit strange at first.
PostPosted: Wed Nov 28, 2012 11:31 am Up
Loctite UV glue for glass.
It's special glue exactly for this job that cures with sunlight (!)
