Posted: Sat Jun 22, 2013 12:41 pm |
Have any of you guys run a compression test on your 180 engines?
I am looking for test results to compare.... any info is appreciated
Posted: Sat Jun 22, 2013 1:31 pm |
Schumi has , PM him.
Posted: Sat Jun 22, 2013 2:31 pm |
Just found my results from an old post
cylinder 1: 148psi, 2: 150psi, 3: 152psi, 4: 150psi
Hope that helps
Posted: Sat Jun 22, 2013 3:26 pm |
There is no set fiqure as every engine is individual. Just no more than 10 percent variation across the four
| Team Impossible Possible
Posted: Sat Jun 22, 2013 4:13 pm |
I am working on averages on this one Addaz.
I have 180, 166, 179, 165
Posted: Sun Jun 23, 2013 8:34 am |
Addaz wrote: |
There is no set fiqure as every engine is individual. Just no more than 10 percent variation across the four |
+1
Posted: Tue Jun 25, 2013 9:06 am |
MATHS LESSON-NO FEE...
180+166+179+165÷4=172.5average psi
172.5÷100=1.725 so 1%=1.725 ×10=17.25
So 10%=17.25psi
Range of 10% MEANS between 180(upper limit)
And (180-17.25or-10%of avg. So 162.75)162.75(lower limit)is ok here...so between 180 and 162.75psi is serviceable,so yours,going off your readings should be fine..phew!!!
Posted: Tue Jun 25, 2013 9:33 am |
That's confused the hell out of me
Posted: Tue Jun 25, 2013 1:01 pm |
glad you don't charge by the hour........... these figures were gained with the butterflies closed on the ITB`s...... I can only assume the variation will be slightly closer with full opening on the throttle. But I am glad you agree they are serviceable
