Posted: Sat Oct 19, 2013 10:58 am |
Posted: Sat Oct 19, 2013 11:25 am |
I think you should be able to see it from those angles, so my guess is it's been taken out
Posted: Sat Oct 19, 2013 12:17 pm |
Our 138 CC has a cat and a silencer before the rear axle ... basically where your straight-through pipe is ...
Not been under a 180 GTi though so might be wrong as exhausts might be different ...
Posted: Sat Oct 19, 2013 1:11 pm |
the cats not there, the shinny pipe is your decat, you have a decat/no resonator centre section and then the back box
Posted: Sat Oct 19, 2013 1:14 pm |
Yep cats been taken off mate
Posted: Sat Oct 19, 2013 1:16 pm |
cant really see, but the honeycomb heat shield infront of my janspeed centre box is the cat, was my old 180
Posted: Sat Oct 19, 2013 1:33 pm |
What's the second lambda sensor plugged into? Can see the clips that hold the cable but no sensor.
Posted: Sat Oct 19, 2013 4:09 pm |
Dan- wrote: |
the cats not there, the shinny pipe is your decat, you have a decat/no resonator centre section and then the back box | kwl thanks
so it looks like the pipe connected to the shiny pipe is original pipe cat should attached to? Think if I unbolt shiny pipe backwards the rest of a standard system should fit?
Edward wrote: |
What's the second lambda sensor plugged into? Can see the clips that hold the cable but no sensor. |
i have no idea not seen it only see it from that side of the pic. Need to get under and have a better look really.
Posted: Sat Oct 19, 2013 6:15 pm |
NorthantsBen wrote: |
so it looks like the pipe connected to the shiny pipe is original pipe cat should attached to? Think if I unbolt shiny pipe backwards the rest of a standard system should fit? |
The standard cat has a flexi which attaches it to the manifold so you would have to remove the bit before it gets shiny to get a standard cat and exhaust system on there.
Posted: Sun Oct 20, 2013 2:01 am |
Jake86 wrote: |
The standard cat has a flexi which attaches it to the manifold so you would have to remove the bit before it gets shiny to get a standard cat and exhaust system on there. |
cool cheers :)
