Latest: Andyblue64
Overall: 17123
Online Now [22]:
Visitors: 21
Today: 109414
Total: 98620716
Forums › The Car › 206 Talk › The 180 cat / exhaust....
PostPosted: Sat Oct 19, 2013 10:58 am Up
The exhaust i have on this 206 is far too loud so loud im not driving it, am guessing that there is no cat, i know the back box is not orignal but where does the cat normally sit? does it look like its been cut up? cant see no sensors.... cheers Very Happy
bashyy1
PostPosted: Sat Oct 19, 2013 11:25 am Up
I think you should be able to see it from those angles, so my guess is it's been taken out
Aegean Blue Gti 180.
Project Thread
gazza82
PostPosted: Sat Oct 19, 2013 12:17 pm Up
Our 138 CC has a cat and a silencer before the rear axle ... basically where your straight-through pipe is ...
Not been under a 180 GTi though so might be wrong as exhausts might be different ...
Dan-
PostPosted: Sat Oct 19, 2013 1:11 pm Up
the cats not there, the shinny pipe is your decat, you have a decat/no resonator centre section and then the back box
L5_UKS
PostPosted: Sat Oct 19, 2013 1:14 pm Up
Yep cats been taken off mate
Dan-
PostPosted: Sat Oct 19, 2013 1:16 pm Up
cant really see, but the honeycomb heat shield infront of my janspeed centre box is the cat, was my old 180
PostPosted: Sat Oct 19, 2013 1:33 pm Up
What's the second lambda sensor plugged into? Can see the clips that hold the cable but no sensor.
PostPosted: Sat Oct 19, 2013 4:09 pm Up
kwl thanks Smile
so it looks like the pipe connected to the shiny pipe is original pipe cat should attached to? Think if I unbolt shiny pipe backwards the rest of a standard system should fit?
i have no idea not seen it only see it from that side of the pic. Need to get under and have a better look really.
Jake86
PostPosted: Sat Oct 19, 2013 6:15 pm Up
The standard cat has a flexi which attaches it to the manifold so you would have to remove the bit before it gets shiny to get a standard cat and exhaust system on there. Smile
PostPosted: Sun Oct 20, 2013 2:01 am Up
cool cheers Smile :)
