Latest: Worthy967
Overall: 17143
Online Now [608]:
Visitors: 607
Today: 140004
Total: 115473016
Forums › The Car › 206 Problems › Codes after ECU reading
EuroPeugeot
PostPosted: Fri Apr 15, 2011 3:30 pm Up
Wanted your advise on 3 codes coming up on my car.
I'm hoping the VVT fault will be cured by just an unplug and clean? - 206info.co.uk/Forums/v...enoid.html
Any advise or on the air con faults? At the moment as you an guess, the air con doesn't work / blow out cold air. I was waiting for the hot weather to come in, and just get a re-gas. However these faults seem to show there's a bigger problem..
kieron
PostPosted: Sat Apr 16, 2011 12:35 am Up
Is you aircon working? i would say its a relay or a break in the looms?
I had that vvt fault and i just had to replace it for a new unit, if you buy one get a new one but if second hand you could find a cheap one out of a 1.4vvt engine
Account suspended
EuroPeugeot
PostPosted: Sat Apr 16, 2011 2:50 am Up
No, air con isn't working, never had is gassed since I've owned it. I thought that was why it didn't.
What's the prices on a replacement VVT?
