Posted: Sat Jun 11, 2011 8:43 am |
Got quite a silly question to ask, as I've done my flywheel and clutch on my 180 and judder was still there, I've now thought of the mountings, I've got sum1 to hold the car on bite point while I check the mounts the engine is shaking quite badly, should there be any movement in any mount?
Thanks Dan
Posted: Sat Jun 11, 2011 9:02 am |
yes. there should be a bit movement in the engine mounts. (at least for the stock mount)
otherwise your car will vibrate like hell.
but you shouldn't be able to move the mounts with your hand.
Posted: Sat Jun 11, 2011 9:05 am |
Alright thanks I can't by hand but can with a scree driver, yeah it sounds like a helicopter taking off when on bite point xD
Posted: Sat Jun 11, 2011 9:08 am |
if there is no obvious damage on the mounts i wouldn't worry too much.
Posted: Sat Jun 11, 2011 10:14 am |
Dan- wrote: |
Thanks Dan |
Hmm sounds like the probably i got! If i get any further ill let you know mate!
Posted: Sat Jun 11, 2011 10:44 am |
Even with standard mounts you will be able to move the top of the engine by about 5-10mm.
