Latest: tebas93089
Overall: 17179
Online Now [265]:
Visitors: 264
Today: 27227
Total: 138546836
Forums › The Car › 206 Talk › compression test
compression test
Dan-
PostPosted: Sat Oct 08, 2011 8:43 am Up
I'm going to perform a compression test on my 180 just wondered if anybody knows what the average reading should be, or do I just test them all and see, also is it best to doit with all plugs removed or just the one your testing
Thanks Dan
macj
PostPosted: Sat Oct 08, 2011 8:46 am Up
test all cylinders and compare the results. remove all plugs and do each cylinder in turn. You only need to crank it a few cycles each time.
Show your results on here for a diagnosis
Use a screw in CT by the way
PostPosted: Sat Oct 08, 2011 8:52 am Up
They should be within about 10% of each other shouldn't they?
macj
PostPosted: Sat Oct 08, 2011 8:53 am Up
Yes they should.... keeping the plugs for each cylinder in order can be useful too
Dan-
PostPosted: Sat Oct 08, 2011 8:59 am Up
Thanks I will do, I think its a screw in 1 he's got, i hope there all around the same
Dan-
PostPosted: Sun Oct 09, 2011 5:47 am Up
Just done my compression test, the results are cylinder 1: 148psi, 2: 150, 3: 152, 4: 150
Do them results sound about right
Thanks Dan
Mattie-RS
PostPosted: Sun Oct 09, 2011 6:50 am Up
There all round about the same so yea
macj
PostPosted: Sun Oct 09, 2011 7:00 am Up
not a lot wrong there.... why did you test it. Was something not right?
Dan-
PostPosted: Sun Oct 09, 2011 7:34 am Up
That's okay then Smile my friend just had 1 so thought I would just check them
Dan-
PostPosted: Sun Oct 09, 2011 7:59 am Up
Also would it be normal for it to bring on Eml after, it has now turned off but took a drive and a turn off turn on to do so, the only reason I can think it came on is due to turning the car over with no coil pack plugged in,
PostPosted: Sun Oct 09, 2011 8:00 am Up
Yeah that sounds plausible due to the ECU detecting a error
Dan-
PostPosted: Sun Oct 09, 2011 11:20 am Up
I hope that was the cause, ill plug it in on the scanner next week and see
PostPosted: Sun Oct 09, 2011 12:09 pm Up
don't quote on me but the value seems low to me
Schumi
PostPosted: Sun Oct 09, 2011 1:52 pm Up
I think its to low. 100.000 km GTI138 engine giving 160 psi with stock 10.8:1 compression ratio. 11:1 CR GTI180 engine should be much more than GTI138. I guess 165-170.
2005 206 RC RED
Dan-
PostPosted: Sun Oct 09, 2011 2:15 pm Up
Hmm well I did only let it turn over twice or so, that could be why I hope
