Latest: Beduff1977
Overall: 17134
Online Now [553]:
Visitors: 552
Members: 1
Today: 215521
Total: 110069881
Forums › The Car › 206 Talk › Bumper not secure
Bumper not secure
acotton21
PostPosted: Mon Oct 10, 2011 1:31 pm Up
Just swapped front bumpers over for non spot to spot untill i can afford a gti one. Havent got the side bit fixed properly as i need to get 2 little bolts on but the question is will it efect MOT at all? just need to make sure as booked in on wednesday Thanks
PostPosted: Mon Oct 10, 2011 1:32 pm Up
Sport is a GTi one
No it will be fine, as long as its not dragging on the floor
Dan-
PostPosted: Mon Oct 10, 2011 1:35 pm Up
it may do, it might be worth just putting a cable tie there in stead until you can get 2 bolts
acotton21
PostPosted: Mon Oct 10, 2011 1:36 pm Up
looks like this
richpowell91
PostPosted: Mon Oct 10, 2011 1:39 pm Up
As said just thread a cable tie through the bolt hole and tighten to secure it till you get the bolts, thats how ive fitted mine for the time being and is holding up fine.
20619d
PostPosted: Mon Oct 10, 2011 2:01 pm Up
do wot i did cut the oe bolt out and then cut the to spike bits off then drill hole where the spikes was. then put to bolts and nuts on each side. holds on good
