Latest: tbafonso
Overall: 17130
Online Now [146]:
Visitors: 145
Today: 18188
Total: 103948565
Forums › The Car › 206 Problems › Bypass GTi 180 oil cooler
SinfulDesignCom
PostPosted: Wed Nov 28, 2012 6:54 pm Up
I have read somewhere here that the standard GTi bottom hose does the job of bypassing the oil cooler on the 180...
..but the clip at the radiator is different. Will the GTi hose fit this even though it should be clipped on??
Thanks in advance
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
PostPosted: Thu Nov 29, 2012 1:59 am Up
So the radiator hose doesnt use a jubilee clip?
Uz
PostPosted: Thu Nov 29, 2012 11:47 am Up
I've noticed it's different but not looked into it tbh anymore than that. I'm looking at fitting a Mocal oil cooler kit in the new year once I have the cams and headwork done on the 180 and this is definitely a top I'm keeping my eye on to see what the results are and if you can by pass it in any way.
PostPosted: Thu Nov 29, 2012 1:36 pm Up
I've never seen the point in an oil cooler even on my 206 so does a road going 180 really need one?
Uz
PostPosted: Thu Nov 29, 2012 2:09 pm Up
a road going 180 may not need one but in the new year I'll be looking at tracking it... mainly at the shows like TRAX and FCS and Pugfest which is the main reason I'm looking at fitting a oil cooler. Plus if it's got one already fitted, I'll only be uprating it.
Dan-
PostPosted: Thu Nov 29, 2012 2:22 pm Up
i managed a track day in mine, it was on average 20c air temp and i did about 10 laps of brands hatch and my oil never got to the point i though of f**k best stop, i did go to about 120c - 130c
SinfulDesignCom
PostPosted: Thu Nov 29, 2012 3:27 pm Up
Standard 180 will not need one - but put cams and tb in and it will generate more heat and you will need one then - hence my reason for doing this.
The 180 has a cooler as standard in the form of a sandwich plate between the filter, and this uses a bottom hose which incorporates this. But it is less than useless and is not up to the job of cooling for a modified lump.
So... no answers yet??
Mattie-RS
PostPosted: Thu Nov 29, 2012 3:34 pm Up
I have the same issue with my 197
Could you just cut the two pipes as close to the main coolant pipe then plug them?!?
Then just remove the water heat transfer plate for a oil cooler sandwich plate
Dan-
PostPosted: Thu Nov 29, 2012 4:46 pm Up
thats surprising matt! alwyas imagined Renault would have fitted one as standard on to there RS range!
Mattie-RS
PostPosted: Thu Nov 29, 2012 5:04 pm Up
I know! Mine has the two pipes from the return coolant pipe like the 180 does. Cheap way of doing it to a standard car I'd imagine
SinfulDesignCom
PostPosted: Thu Nov 29, 2012 5:06 pm Up
Nope - after research - it will not work. It has a metal collar on the rad end which the standard GTi does not have. Apparently the late post 2000 306 will be closest...
Going to a breakers tomorrow - will keep you updated as I am sure this post will be useful in the future to others...
Dan-
PostPosted: Thu Nov 29, 2012 5:09 pm Up
i would imagine your right! not expensive to put an aftermarket one on really is it, i just found not need when i had the 180, i know my scooby has one but i will be fitting a bigger aftermarket 1 when i go nurburgring you should come along aswell !!!!
SinfulDesignCom
PostPosted: Thu Nov 29, 2012 5:34 pm Up
That is high on the list of destinations when finished... definately =)
Dan-
PostPosted: Thu Nov 29, 2012 5:38 pm Up
i can't wait sort it all out!! Very Happy
Mattie-RS
PostPosted: Fri Nov 30, 2012 5:38 pm Up
Don't forget my invite Razz
