Posted: Mon Mar 12, 2012 1:38 pm |
Hi, I've just purchased a set of Avo GTZ coilovers and going to fit them this weekend, now should i be looking to replace the top mounts, ARB bushes, and drop links while I'm doing to, i changed my drop links about 5 months ago?
Thanks Dan
Posted: Mon Mar 12, 2012 2:07 pm |
check them while u do the replacing job,if they are in good shape,keep them,if not,replace them
Posted: Mon Mar 12, 2012 2:25 pm |
Change your top mounts as it will save you a job later plus you already have the shock out
Posted: Tue Mar 13, 2012 10:13 am |
Ive spoken to euro car parts and they will do both top mounts for £45 will be they good enough quallity? also will i only need to use the bearing or the rubber mounts aswell?
Dan
Posted: Tue Mar 13, 2012 10:23 am |
Trade Rating: +46
YER IDE CHANGE THEM
Posted: Tue Mar 13, 2012 2:41 pm |
will get them friday, also if anybody knows the size of the nuts and bolts ill replace all of them reason i ask is i can get them all from work friday and would be very handy to know before hand
thanks Dan
Posted: Tue Mar 13, 2012 3:02 pm |
Dan- wrote: |
Dan |
Make sure they are both the same make and come with bearings
