Latest: Stu-mill
Overall: 17131
Online Now [223]:
Visitors: 222
Today: 84534
Total: 104770082
Forums › The Car › 206 Problems › coilovers will not adjust!
anton1989
PostPosted: Sun Nov 25, 2012 11:35 am Up
Trade Rating: +16
lol as above. got some coilovers from a car i was breaking plan on selling them but they will not adjust! wd40 not helping. one is rusty but the other one is ok neither of the move an the tool i have is s**t to say the least as its not a fixed one if you know what i mean? what else can i put on them to get them to budge?
also are these v maxx?
PostPosted: Sun Nov 25, 2012 11:43 am Up
get the threads really clean and soak them for a few days in wd40 and oil.
then put them in a vice or hold them securely against something if not and gently try and free off the collars by tapping in the slots with a hammer and drift/big punch until the start to move.
anton1989
PostPosted: Sun Nov 25, 2012 11:45 am Up
Trade Rating: +16
will wire wool be ok to clean the threads?
broadblaster
PostPosted: Sun Nov 25, 2012 11:52 am Up
use a wire brush the clean up the threads the leave them in a pot full of oil or derv for a day or two then try again mate
on a back road playing
PostPosted: Sun Nov 25, 2012 11:55 am Up
its not really strong enough to take the rust off Sad get a nice stiff wire brush from halfords or a diy shop would be better
PostPosted: Sun Nov 25, 2012 11:58 am Up
you got the C spanner??
PostPosted: Sun Nov 25, 2012 1:37 pm Up
Plus Gas is a great releasing oil...try that.
Silvery206
PostPosted: Sun Nov 25, 2012 2:38 pm Up
Soak them in diesel overnight Wink
Silvery 206
anton1989
Trade Rating: +16
yes i have it but its a wierd one like this
not like this
it keep folding in when you put force on it
will try the above things see what happens
anton1989
PostPosted: Sun Nov 25, 2012 2:39 pm Up
Trade Rating: +16
PostPosted: Sun Nov 25, 2012 2:43 pm Up
They can be properly stuck sometimes, i had to use a hammer/chisel to start with when i first got mine
simonster_14
PostPosted: Sun Nov 25, 2012 2:48 pm Up
could put some spring compressers on, take the top mounts off so there is minimal stress on the collars then wire brush and dowse in wd every few hours..
you can buy coilover covers to stop this from happening Wink or atleast reduce it
Dan-
PostPosted: Sun Nov 25, 2012 3:41 pm Up
+ 1 on plusgas! the best ive used so far! other than loctite freeze and relise Smile
anton1989
PostPosted: Sun Nov 25, 2012 3:49 pm Up
Trade Rating: +16
there is no stress on them as you can see in the second from last pic Wink
gaffa786
PostPosted: Mon Nov 26, 2012 5:32 pm Up
heat it with a blow torch then give it a turn Smile
