Latest: sparrowdclxvi
Overall: 17139
Online Now [60]:
Visitors: 59
Today: 3321
Total: 113278894
Forums › The Car › 206 Problems › 206 Gti 180 on 3 cylinders after 2 mins. Codes P0300, P1336
kernel
PostPosted: Tue Nov 27, 2012 9:07 am Up
Hi
When cold, car starts perfect on 4 cylinders.
After 2-3 minutes of warming up and driving (on idle anything occurs), the car shows message antipollution fault, then catalytic converter fault, and (this is really strange) ABS/ESR fault (and ESP deactivates ), and car runs on 3 cylinders (pof-pof sound, vibrations...). And MIL switch on. Confused
If I stop engine and restart, car runs well for 10-15 seconds and then messages again and 3 cyl.
I did a scan and this are the results:
P0300: Random Misfire
P1336: (no description)
P0341: Camshaft Position Sensor Circuit Range/Performance
It's not spark plugs, or ingition coils (changed both).
I also think I can discard a compression issue, because for the first 2 minutes the car goes well. If its open valve it would be failing always.
I think injectors could be the problem. But then again, P0300 means a problem on various or random cylinders... which sounds strange if one injector is failing. Wall Bang
I think EGR it's okay because I checked with OBDII while engine was running and it opens/closes OK.
The code P0341 related to Cam sensor... could a malfuncion on sensor cause going on 3 cylinders? Sounds strange. I think P0341 its more a symptom than the cause of the problem.
Maybe MAF/MAP failing?
Any advice will be appreciated! Smile
Dan-
PostPosted: Tue Nov 27, 2012 2:19 pm Up
worth a try vvt solenoid give it a clean, might not be the problem but worth a go, it normally makes the car run like a 1.2 but not heard it giving a misfire
PostPosted: Tue Nov 27, 2012 2:36 pm Up
www.206info.co.uk/Foru...ntrol.html
Looks like your camshaft sensor is playing up. Take it out and clean it up, might need replacing.
PostPosted: Tue Nov 27, 2012 2:37 pm Up
P1336 Crank / Cam Sensor Range / Performance
kernel
PostPosted: Tue Nov 27, 2012 3:27 pm Up
Where's VVt slenoid?
Steve206 wrote:
http://www.206info.co.uk/Forums/viewtopic/t=34915/highlight=cruise+control.html
So I get both CAM & Crank errors Mad I localized Cam sensor, though I don't know how to remove it for clean. No idea where is Crank sensor Confused
Appart from that, I think that maybe ECU is disconnecting some cylinder when detects a misfire, in order to preserve catalytic converter. Do you know if Peugeot ECUs are "so intelligent" to do that? I say that because car goes bad just after throwing all faulty messages, and I know some cars do that.
PostPosted: Tue Nov 27, 2012 4:20 pm Up
I would ignore P300 completely, i more than likely just think its a ghost code created by the misfire caused by the other codes
Try another camshaft sensor since there is two codes of this item, and i doubt you have the facility to scope it, so get a second hand one cheap and just replace it
See if the fault clears and the vehicle runs right
PostPosted: Tue Nov 27, 2012 4:29 pm Up
Top right back of cylinder head for the cam sensor.
kernel
PostPosted: Wed Nov 28, 2012 6:37 am Up
It's a good point. I'll check CAM sensor. Peugeot Part number is 1920 8W ?
I think is this one:
but how I remove it? Thanks again
PostPosted: Wed Nov 28, 2012 7:20 am Up
Not sure on the 180. But on the 138 gti it's on the top back right, it's essentially the same head, so should be the same place.
kernel
PostPosted: Wed Nov 28, 2012 11:20 am Up
I removed it and I gave it a good clean.
Refitted again, and still having the problem.
206++
kernel
PostPosted: Wed Nov 28, 2012 1:08 pm Up
if I disconnect the cable that reachs to the cam sensor, could I damage the engine in some way?
Do you think its worth a try to get some conclusion?
206++
theoldman
PostPosted: Wed Nov 28, 2012 3:34 pm Up
What about the coil pack playing up. Make sure you have a good spark on each plug. Can cause the Ecu to throw up a sensor code.
kernel
PostPosted: Thu Nov 29, 2012 1:16 pm Up
as I said its not coil packs.
I bought a new cam sensor, should arrive in some days. Lets see if it works...
If not, I'll try injectors...
206++
kernel
PostPosted: Tue Dec 04, 2012 8:20 am Up
Apparently solved - run the car for 15 minutes and everything OK Very Happy
This confirms that BSI disconnected on purpose some cylinder when getting wrong data, I guess Shocked
206++
bezford
PostPosted: Tue Dec 04, 2012 10:22 am Up
Do an ecu soft reboot if problems persist...see how to guide .......
..this is very likely the fix...and its free
R.HYDE
